查看: 3870|回復: 1
arduino 跟arduino USB 控PS3問題
發表於 2014-12-4 14:41:19 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
我最近購買  MEGA2560跟 KEYES的USB HOST 我燒入他範例但是,好像沒抓到我的PS3搖桿,請教如何抓到???
因為燒入程式後,接線按了一些遙桿按鍵或等一段時間,他只有出現一段文字,就確定arduino 好像沒有抓到。
請問哪裡要改進,只出現 OSC did bot start
HOST範例程式
#include <PS3USB.h>
// Satisfy IDE, which only needs to see the include statment in the ino.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#endif
USB Usb;
/* You can create the instance of the class in two ways */
PS3USB PS3(&Usb); // This will just create the instance
//PS3USB PS3(&Usb,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
boolean printAngle;
uint8_t state = 0;
  Serial.begin(115200);
  while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
  if (Usb.Init() == -1) {
    Serial.print(F("\r\nOSC did not start"));
    while (1); //halt
  Serial.print(F("\r\nPS3 USB Library Started"));
  Usb.Task();
  if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
    if (PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
      Serial.print(F("\r\nLeftHatX: "));
      Serial.print(PS3.getAnalogHat(LeftHatX));
      Serial.print(F("\tLeftHatY: "));
      Serial.print(PS3.getAnalogHat(LeftHatY));
      if (PS3.PS3Connected) { // The Navigation controller only have one joystick
        Serial.print(F("\tRightHatX: "));
        Serial.print(PS3.getAnalogHat(RightHatX));
        Serial.print(F("\tRightHatY: "));
        Serial.print(PS3.getAnalogHat(RightHatY));
    // Analog button values can be read from almost all buttons
    if (PS3.getAnalogButton(L2) || PS3.getAnalogButton(R2)) {
      Serial.print(F("\r\nL2: "));
      Serial.print(PS3.getAnalogButton(L2));
      if (!PS3.PS3NavigationConnected) {
        Serial.print(F("\tR2: "));
        Serial.print(PS3.getAnalogButton(R2));
    if (PS3.getButtonClick(PS))
      Serial.print(F("\r\nPS"));
    if (PS3.getButtonClick(TRIANGLE))
      Serial.print(F("\r\nTraingle"));
    if (PS3.getButtonClick(CIRCLE))
      Serial.print(F("\r\nCircle"));
    if (PS3.getButtonClick(CROSS))
      Serial.print(F("\r\nCross"));
    if (PS3.getButtonClick(SQUARE))
      Serial.print(F("\r\nSquare"));
    if (PS3.getButtonClick(UP)) {
      Serial.print(F("\r\nUp"));
      PS3.setLedOff();
      PS3.setLedOn(LED4);
    if (PS3.getButtonClick(RIGHT)) {
      Serial.print(F("\r\nRight"));
      PS3.setLedOff();
      PS3.setLedOn(LED1);
    if (PS3.getButtonClick(DOWN)) {
      Serial.print(F("\r\nDown"));
      PS3.setLedOff();
      PS3.setLedOn(LED2);
    if (PS3.getButtonClick(LEFT)) {
      Serial.print(F("\r\nLeft"));
      PS3.setLedOff();
      PS3.setLedOn(LED3);
    if (PS3.getButtonClick(L1))
      Serial.print(F("\r\nL1"));
    if (PS3.getButtonClick(L3))
      Serial.print(F("\r\nL3"));
    if (PS3.getButtonClick(R1))
      Serial.print(F("\r\nR1"));
    if (PS3.getButtonClick(R3))
      Serial.print(F("\r\nR3"));
    if (PS3.getButtonClick(SELECT)) {
      Serial.print(F("\r\nSelect - "));
      PS3.printStatusString();
    if (PS3.getButtonClick(START)) {
      Serial.print(F("\r\nStart"));
      printAngle = !printAngle;
    if (printAngle) {
      Serial.print(F("\r\nPitch: "));
      Serial.print(PS3.getAngle(Pitch));
      Serial.print(F("\tRoll: "));
      Serial.print(PS3.getAngle(Roll));
  else if (PS3.PS3MoveConnected) { // One can only set the color of the bulb, set the rumble, set and get the bluetooth address and calibrate the magnetometer via USB
    if (state == 0) {
      PS3.moveSetRumble(0);
      PS3.moveSetBulb(Off);
    } else if (state == 1) {
      PS3.moveSetRumble(75);
      PS3.moveSetBulb(Red);
    } else if (state == 2) {
      PS3.moveSetRumble(125);
      PS3.moveSetBulb(Green);
    } else if (state == 3) {
      PS3.moveSetRumble(150);
      PS3.moveSetBulb(Blue);
    } else if (state == 4) {
      PS3.moveSetRumble(175);
      PS3.moveSetBulb(Yellow);
    } else if (state == 5) {
      PS3.moveSetRumble(200);
      PS3.moveSetBulb(Lightblue);
    } else if (state == 6) {
      PS3.moveSetRumble(225);
      PS3.moveSetBulb(Purble);
    } else if (state == 7) {
      PS3.moveSetRumble(250);
      PS3.moveSetBulb(White);
    state++;
    if (state > 7)
      state = 0;
 樓主| 發表於 2014-12-5 11:55:51 | 只看該作者
請問有解嘛!!??
GMT+8, 2026-10-3 07:00 , Processed in 0.160004 second(s), 9 queries , Apc On.
