查看: 3937|回復: 0
想請教一下 ARDUINO的SENSOR 大氣壓力傳感器BMP180
發表於 2014-12-25 19:35:07 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
https://www.youtube.com/watch?v=z9AzZM1-Dns#t=459
今天想要用BMP180這塊SENSOR可是我照著這影片裡面操作
偵錯沒問題也可以"燒錄",ANALOG IN 也沒接錯
電源3.3V 5V 也都試過了
LIBRARY也有匯入
SENSOR 傳給電腦的數值一直是0度,想請問各位前輩有沒有類似經驗可以提供
附上程式碼
#include <Wire.h>
#include "Adafruit_BMP085.h"
  This is an example for the BMP085 Barometric Pressure & Temp Sensor
  Designed specifically to work with the Adafruit BMP085 Breakout
  ----> https://www.adafruit.com/products/391
  These displays use I2C to communicate, 2 pins are required to
  interface
  Adafruit invests time and resources providing this open source code,
  please support Adafruit and open-source hardware by purchasing
  products from Adafruit!
  Written by Limor Fried/Ladyada for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
// Connect VCC of the BMP085 sensor to 3.3V (NOT 5.0V!)
// Connect GND to Ground
// Connect SCL to i2c clock - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 5
// Connect SDA to i2c data - on '168/'328 Arduino Uno/Duemilanove/etc thats Analog 4
// EOC is not used, it signifies an end of conversion
// XCLR is a reset pin, also not used here
Adafruit_BMP085 mySensor;
float temC;
float temF;
float pressure;
mySensor.begin();
   temC=mySensor.readTemperature();
   temF=temC*1.8+32;
   pressure=mySensor.readPressure();
   Serial.print("the tmp is:");
    Serial.print(temF);
     Serial.println("degree F.");
      Serial.print("the pressure is:");
       Serial.print(pressure);
        Serial.println("pa.");
         Serial.println("");
執行結果
執行結果
GMT+8, 2026-7-5 10:26 , Processed in 0.097884 second(s), 11 queries , Apc On.
