查看: 6900|回復: 0
3D Printer kit Huxley Reprap
發表於 2015-1-3 14:01:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
Products Description:[size=13.333333969116211px]
Attention: This product is kit package ,need assemble .Thanks .
3d printer Motherboard: melzi main chip 1284 p
3d printer stepper motor A4982 chip
Output power: 24 v input  AC110-220 - v
Print the most large area: 140 x140x110mm
Physical size: 260 x280x280mm
Printing material: ABS, PLA, 1.75 mm in diameter.
Building surface: PCB heating bed, aluminum mesa, in order to reduce the complexity of the assembly, to ensure parts deformation.
nozzle diameter:0.4mm (if you need 0.5mm, please left a message for us)
Precision standard: 0.1 mm
Resolution: 0.0125 mm
Construction speed: 1800 mm/min
Move speed: 1.2 mm/minute
Operation systerm support: Linux  Mac  windows7 or later   XP
Printing software: Repetier Host or Pronterface
Deposition rate: 33 cm/hour
Movement: X and Y and Z axis low friction bushing, X, Y is linear bearing. All welded electronics and built-in microSD card slot for independent printing. Enhanced set, improve the X and Y shaft assembly is convenient Ultra-low print noise, let you print more quiet!
Contain all parts for assembly .
1, 1 pack hardware fittings
2, 5 NEMA14 stepper motors
3, heating bed 1 set of components
4, extrusion units 1 set
5, RP plastic parts 1 bag(total 42 piece. 2 metal coupling)
6, power supplier 1
7, 1 piece motherboard
Besides, we will give you 100g ABS , a set of special little tools and 1m high temperature tap as gifts . Thanks .
GMT+8, 2026-10-3 05:09 , Processed in 0.154720 second(s), 8 queries , Apc On.
