查看: 5078|回復: 2
使用MEGA 1280 作LED矩陣跑馬燈
發表於 2015-1-7 11:53:44 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 bear20591 於 2015-1-7 11:57 編輯
如題請問我想要做16*24(還是24*16)的點矩陣跑馬燈
現在字型抓不到
只會持續亮第一行
掃瞄端是74154*2
輸出端是74373*2
上圖為實際接線圖(麥克風是之後要加的功能,但現在跑馬燈就出不來了...)
程式如下:
int delaymsecond=200;
#define repeat
30
int decoder_74154_1[]={17,18,19,20,21};
int decoder_74154_2[]={22,24,26,28,30};
int buffer_74373_1[]={36,38,40,42,44,46,48,50,52};
int buffer_74373_2[]={37,39,41,43,45,47,49,51,53};
unsigned char code[8][2][16]={
   { {0x00,0x01,0x01,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x01,0x01,0x00},         //"三" 上半部
      {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40} },       //"三" 下半部
    { {0x00,0x00,0x10,0x08,0x84,0xd5,0x85,0xff,0xff,0x85,0xd5,0x84,0x08,0x10,0x00,0x00},         //"電" 上半部
      {0x00,0x00,0x00,0x00,0x1f,0x16,0x16,0xff,0xff,0x96,0x56,0x1f,0x00,0x00,0x00,0x00} },       //"電" 下半部
    { {0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xc2,0xe2,0x32,0x1a,0x0e,0x06,0x00,0x00,0x00},         //"子" 上半部
      {0x00,0x01,0x01,0x01,0x01,0x09,0x11,0x3f,0x7f,0x01,0x01,0x01,0x01,0x01,0x01,0x00} },       //"子" 下半部
    { {0x00,0x00,0x00,0xfc,0x24,0x24,0x24,0xfc,0xfc,0x24,0x24,0x24,0xfc,0x00,0x00,0x00},         //"甲" 上半部
      {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3f,0x3f,0x00,0x00,0x00,0x00,0x00,0x00,0x00} },       //"甲" 下半部
    { {0x00,0x00,0x00,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xfe,0x00,0x00,0x00},         //"3" 上半部
      {0x00,0x00,0x00,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7f,0x00,0x00,0x00} },       //"3" 下半部
    { {0x00,0x00,0x00,0xfe,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xfe,0x00,0x00,0x00},         //"0" 上半部
      {0x00,0x00,0x00,0x7f,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7f,0x00,0x00,0x00} },       //"0" 下半部
    { {0x00,0x00,0x00,0xfe,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0xfe,0x00,0x00,0x00},         //"4" 上半部
      {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7f,0x00,0x00,0x00} },       //"4" 下半部
    { {0x00,0x00,0x00,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0x82,0xfe,0x00,0x00,0x00},         //"2" 上半部
      {0x00,0x00,0x00,0x7f,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x00,0x00} } };     //"2" 下半部
  pinMode(17,OUTPUT); //74154_1 解碼輸出腳
  pinMode(18,OUTPUT);
  pinMode(19,OUTPUT);
  pinMode(20,OUTPUT);
  pinMode(21,OUTPUT);//G2 控制腳
  pinMode(22,OUTPUT); //74154_2 解碼輸出腳
  pinMode(24,OUTPUT);
  pinMode(26,OUTPUT);
  pinMode(28,OUTPUT);
  pinMode(30,OUTPUT);//G2 控制腳
  pinMode(36,OUTPUT);//74373_1_解碼輸出腳
  pinMode(38,OUTPUT);
  pinMode(40,OUTPUT);
  pinMode(42,OUTPUT);
  pinMode(44,OUTPUT);
  pinMode(46,OUTPUT);
  pinMode(48,OUTPUT);
  pinMode(50,OUTPUT);
  pinMode(52,OUTPUT);//Enable G_1 控制腳
  pinMode(37,OUTPUT);//74373_2_解碼輸出腳
  pinMode(39,OUTPUT);
  pinMode(41,OUTPUT);
  pinMode(43,OUTPUT);
  pinMode(45,OUTPUT);
  pinMode(47,OUTPUT);
  pinMode(49,OUTPUT);
  pinMode(51,OUTPUT);
  pinMode(53,OUTPUT);//Enable G_2 控制腳
  while (1)   // 無窮盡迴圈
for (int i=0;i<8;i++)  // 八個字
for (int j=0;j<repeat;j++)  // 重複掃瞄repeat次
for (int scan=0;scan<16;scan++)  // 掃瞄迴圈
buffer_74373_1=i;  // 關閉LED(防殘影)
                                         buffer_74373_2=i;
decoder_74154_1[scan]=scan;  // 輸出掃瞄信號
delay(1);  // 延遲1ms
}   // 完成掃瞄一個字型
}  // 完成重複repeat次(j迴圈)
我知道很多問題...
拜託各位大大幫助了(其實是專題做不出來...
發表於 2015-1-7 16:22:46 | 只看該作者
本帖最後由 pizg 於 2015-1-7 16:53 編輯
回復 1# bear20591
   請問你做過8x8了嗎?建議你先做 8x8,
再做 8X16,
最後才做 16x64.
 樓主| 發表於 2015-1-9 19:42:48 | 只看該作者
8*8有用8951做過,直接用接腳輸出,沒有用到解碼
8951與arduino兩者之間寫法是不同的?
還有我現在要用解碼器掃瞄,還是要直接每個字型都打在迴圈裡讓它跑?
但這樣記憶體可能不夠?
死線要到了阿...(x
GMT+8, 2026-10-3 11:07 , Processed in 0.184636 second(s), 12 queries , Apc On.
