本帖最後由 zxcvb1594 於 2015-1-9 19:46 編輯
S4AFirmware15.ino
(6.42 KB, 下載次數: 3910)
附上上船韌體
目前我想要用S4A來控制arduino的模組:手指測心跳.IR紅外線(發射接收)使用的是Arduino UNO板
坤喬科技的
#37-34 紅外線發射 KTDUINO傳感器
#37-35 紅外線接收 KTDUINO傳感器感器
#37-19 手指測心跳 KTDUINO傳感器
先貼上韌體
// NEW IN VERSION 1.5:
// Changed pin 8 from standard servo to normal digital output
// NEW IN VERSION 1.4:
// Changed Serial.print() for Serial.write() in ScratchBoardSensorReport function to make it compatible with latest Arduino IDE (1.0)
// NEW IN VERSION 1.3:
// Now it works on GNU/Linux. Also tested with MacOS and Windows 7.
// timer2 set to 20ms, fixing a glitch that made this period unstable in previous versions.
// readSerialport() function optimized.
// pulse() modified so that it receives pulse width as a parameter instead using a global variable.
// updateServoMotors changes its name as a global variable had the same name.
// Some minor fixes.
// Thanks to Jorge Gomez for all these new fixes!
#define TIMER2_PRELOAD 100
char outputs[10];
int states[10];
unsigned long initialPulseTime;
unsigned long lastDataReceivedTime;
volatile boolean updateServoMotors;
volatile boolean newInterruption;
Serial.begin(38400);
Serial.flush();
configurePins();
configureServomotors();
lastDataReceivedTime = millis();
if (updateServoMotors)
sendUpdateServomotors();
sendSensorValues();
updateServoMotors = false;
readSerialPort();
void configurePins()
for (int index = 0; index < 10; index++)
states[index] = 0;
pinMode(index+4, OUTPUT);
digitalWrite(index+4, LOW); //reset pins
pinMode(2,INPUT);
pinMode(3,INPUT);
outputs[0] = 'c'; //pin 4
outputs[1] = 'a'; //pin 5
outputs[2] = 'a'; //pin 6
outputs[3] = 'c'; //pin 7
outputs[4] = 's'; //pin 8
outputs[5] = 'a'; //pin 9
outputs[6] = 'd'; //pin 10
outputs[7] = 'd'; //pin 11
outputs[8] = 'd'; //pin 12
outputs[9] = 'd'; //pin 13
void configureServomotors() //servomotors interruption configuration (interruption each 10 ms on timer2)
newInterruption = false;
TCCR2A = 0;
TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
TIMSK2 = 1<<TOIE2; //timer2 Overflow Interrupt
TCNT2 = TIMER2_PRELOAD; //start timer
void sendSensorValues()
int sensorValues[6], readings[5], sensorIndex;
for (sensorIndex = 0; sensorIndex < 6; sensorIndex++) //for analog sensors, calculate the median of 5 sensor readings in order to avoid variability and power surges
for (int p = 0; p < 5; p++)
readings[p] = analogRead(sensorIndex);
InsertionSort(readings, 5); //sort readings
sensorValues[sensorIndex] = readings[2]; //select median reading
//send analog sensor values
ScratchBoardSensorReport(sensorIndex, sensorValues[sensorIndex]);
//send digital sensor values
ScratchBoardSensorReport(6, digitalRead(2)?1023:0);
ScratchBoardSensorReport(7, digitalRead(3)?1023:0);
void InsertionSort(int* array, int n)
for (int i = 1; i < n; i++)
for (int j = i; (j > 0) && ( array[j] < array[j-1] ); j--)
swap( array, j, j-1 );
void swap (int* array, int a, int b)
int temp = array[a];
array[a] = array;
array = temp;
void ScratchBoardSensorReport(int sensor, int value) //PicoBoard protocol, 2 bytes per sensor
Serial.write( B10000000
| ((sensor & B1111)<<3)
| ((value>>7) & B111));
Serial.write( value & B1111111);
void readSerialPort()
int pin, inByte, sensorHighByte;
if (Serial.available() > 1)
inByte = Serial.read();
if (inByte >= 128) // Are we receiving the word's header?
sensorHighByte = inByte;
pin = ((inByte >> 3) & 0x0F);
while (!Serial.available()); // Wait for the end of the word with data
if (inByte <= 127) // This prevents Linux ttyACM driver to fail
states[pin - 4] = ((sensorHighByte & 0x07) << 7) | (inByte & 0x7F);
updateActuator(pin - 4);
else checkScratchDisconnection();
void reset() //with xbee module, we need to simulate the setup execution that occurs when a usb connection is opened or closed without this module
for (int pos = 0; pos < 10; pos++) //stop all actuators
states[pos] = 0;
digitalWrite(pos + 2, LOW);
//reset servomotors
//protocol handshaking
sendSensorValues();
void updateActuator(int pinNumber)
if (outputs[pinNumber] == 'd') digitalWrite(pinNumber + 4, states[pinNumber]);
else if (outputs[pinNumber] == 'a') analogWrite(pinNumber + 4, states[pinNumber]);
void sendUpdateServomotors()
for (int p = 0; p < 10; p++)
if (outputs[p] == 'c') servomotorC(p + 4, states[p]);
if (outputs[p] == 's') servomotorS(p + 4, states[p]);
void servomotorC (int pinNumber, int dir)
if (dir == 1) pulse(pinNumber, 1300); //clockwise rotation
else if (dir == 2) pulse(pinNumber, 1700); //anticlockwise rotation
void servomotorS (int pinNumber, int angle)
if (angle < 0) pulse(pinNumber, 600);
else if (angle > 180) pulse(pinNumber, 2400);
else pulse(pinNumber, (angle * 10) + 600);
void pulse (int pinNumber, int pulseWidth)
initialPulseTime = micros();
digitalWrite(pinNumber, HIGH);
while (micros() < pulseWidth + initialPulseTime){}
digitalWrite(pinNumber, LOW);
void checkScratchDisconnection() //the reset is necessary when using an wireless arduino board (because we need to ensure that arduino isn't waiting the actuators state from Scratch) or when scratch isn't sending information (because is how serial port close is detected)
if (millis() - lastDataReceivedTime > 1000) reset(); //reset state if actuators reception timeout = one second
ISR(TIMER2_OVF_vect) //timer1 overflow interrupt vector handler
{ //timer2 => 8 bits counter => 256 clock ticks
//preeescaler = 1024 => this routine is called 61 (16.000.000/256/1024) times per second approximately => interruption period = 1 / 16.000.000/256/1024 = 16,384 ms
//as we need a 20 ms interruption period but timer2 doesn't have a suitable preescaler for this, we program the timer with a 10 ms interruption period and we consider an interruption every 2 times this routine is called.
//to have a 10 ms interruption period, timer2 counter must overflow after 156 clock ticks => interruption period = 1 / 16.000.000/156/1024 = 9,984 ms => counter initial value (TCNT) = 100
if (newInterruption)
updateServoMotors = true;
newInterruption = !newInterruption;
TCNT2 = TIMER2_PRELOAD; //reset timer
目前的想法是 修改S4A擴充偵測Digital輸入
想請問 S4A偵測的Digital輸入有沒有辦法像Analog一樣
是數值 而非true false
若是可以 想請問如何修改(會使用browser)
不知有無神人可教學 感謝! |
