查看: 4460|回復: 0
超音波和步進馬達問題
發表於 2015-1-22 00:42:17 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 fsn103659 於 2015-1-22 11:07 編輯
各位好 這幾天參考了
步進馬達用ULN2003APG驅動電路來轉動馬達
[size=12.7272720336914px]http://atceiling.blogspot.tw/2013/04/arduino.html#.VL_PUkeL86W
[size=12.7272720336914px]參考這版大的接法
[size=12.7272720336914px]我們現在多加一個超音波跟馬達來驅動
這是自己接在麵包板上
超音波顯示出來 0cm 可能讀到值沒有寫入有人建議我寫個副程式 小弟我不太會弄
[size=12.7272720336914px]以下朋友修改程式碼
[size=12.7272720336914px]我們成果是說讓超音波感應到而馬達開始轉動
[size=12.7272720336914px]沒有感應到  馬達不會轉動
#include<Stepper.h>
#defineSTEPS 180  //步進馬達每圈的步進數
//steps:代表馬達轉完一圈需要多少步數。如果馬達上有標示每步的度數,
//將360除以這個角度,就可以得到所需要的步數(例如:360/3.6=100)。(int)
Stepperstepper(STEPS, 12, 11, 10, 9);
const intTrigPinIn = 7; //超音波
const intEchoPinIn = 6; //超音波
voidsetup() {
//initialize serial communication:
//digitalWrite(bz_Pin,LOW);
stepper.setSpeed(140);//將馬達的速度設定成140RPM 最大  150~160
voidloop()
//establish variables for duration of the ping,
// and thedistance result in inches and centimeters:
longdurationIn, inchesIn, cmIn;
longdurationOut, inchesOut, cmOut;
// ThePING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give ashort LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(TrigPinIn,OUTPUT);
pinMode(EchoPinIn,INPUT);
//歡迎光臨
digitalWrite(TrigPinIn,LOW);
delayMicroseconds(2);
digitalWrite(TrigPinIn,HIGH);
delayMicroseconds(5);
durationIn= pulseIn(EchoPinIn, HIGH);
inchesIn =microsecondsToInches(durationIn);
cmIn =microsecondsToCentimeters(durationIn);
Serial.print(inchesIn);
Serial.print("in,");
Serial.print(cmIn);
Serial.print("cmIIIIN");
Serial.println();
delay(30);    //100
if(cmIn<=30.0 )
      stepper.step(180);//正半圈
       Serial.println("--------------------------");
      delay(1000);  //要修正
     stepper.step(0);// 停止運轉
longmicrosecondsToInches(long microseconds)
//According to Parallax's datasheet for the PING))), there are
// 73.746microseconds per inch (i.e. sound travels at 1130 feet per
//second). This gives the distance travelled by the ping, outbound
// andreturn, so we divide by 2 to get the distance of the obstacle.
// See:http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
returnmicroseconds / 74 / 2;
longmicrosecondsToCentimeters(long microseconds)
// Thespeed of sound is 340 m/s or 29 microseconds per centimeter.
// Theping travels out and back, so to find the distance of the
// objectwe take half of the distance travelled.
returnmicroseconds / 29 / 2;
有甚麼地方修改,還請大大們看看一下
GMT+8, 2026-10-5 14:30 , Processed in 0.174615 second(s), 9 queries , Apc On.
