查看: 3149|回復: 1
一般Arduino program 問題
發表於 2015-3-26 19:05:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
各位大大好~
最近我在學arduino的programming, 下面問題令我苦思了一段時間也沒有DEL不了BUG
下面的CODE我想把arrary內的a和b轉成4,0,3,0四個數字, 然後把四個數字順序和放入Step00.Step01,Step02,Step03內...
但是卻改不到想要的結果...有大大看到BUG在那嗎?
PS.為什麼我打char StepBuff[10]改成int StepBuff[10]就有BUG出現~
  1. char Step00;char Step01;char Step02;char Step03;char StepBuff[10];const byte cmmd = 32;char ReceivedChars[cmmd] = {'a', 'b'};int c =0;
  2. void setup() {  Serial.begin(9600);  Serial.println("<Ardunio & Display is ready>");}
  3. void loop() {  while (c == 0){  MappingChars();  LoadingDegree();  Serial.print("The value of StepBuff is");  Serial.println(StepBuff);  Serial.print("The value of Step00 is");  Serial.println(Step00);  Serial.print("The value of Step01 is");  Serial.println(Step01);  c++;}}
  4. void MappingChars(){for(int i=0; i<2; i++){if (ReceivedChars[i] = 'a'){StepBuff[i] = 4;i++;StepBuff[i] = 0;i--;}
  5. if (ReceivedChars[i] = 'b'){StepBuff[i] = 3;i++;StepBuff[i] = 0;i--;}}}
  6. void LoadingDegree(){
  7. for(int k=0; k<4; k++){  if (StepBuff[k] == 0 && k == 0){Step00 = StepBuff[k];}
  8. if (StepBuff[k] == 4 && k == 0){Step00 = StepBuff[k];}}}
 樓主| 發表於 2015-3-26 19:59:17 | 只看該作者
CODE變得好亂..我再貼一次
char Step00;
char Step01;
char StepBuff[10];
int c =0;
void loop() //
  while (c == 0)
  MappingChars();
  LoadingDegree();
  Serial.print("The value of StepBuff is"); //
  c++;
void MappingChars()
StepBuff[i] = 4;
i++;
StepBuff[i] = 0;
i--;
StepBuff[i] = 3;
i++;
StepBuff[i] = 0;
i--;
GMT+8, 2026-10-3 08:34 , Processed in 0.166249 second(s), 8 queries , Apc On.
