查看: 4872|回復: 0
ARDUINO 讀取SD卡至「陣列」問題
發表於 2015-7-10 17:51:06 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
大家好!! 第一次發文,請多指教
我的問題是將sd卡中的txt檔案內容
讀取至arduino陣列,方便做後續處理
我的b.txt內容為
0,38.711,38.712,38.713,38.714,38.715,38.726,38.727,38.728,38.729,38.7210,38.7111,38.7112,38.7213,38.7114,38.7115,38.7116,38.7117,38.7118,38.7119,38.7120,38.71
arduino code為
#include <SPI.h>
#include <SD.h>
File myFile;
char time[3],data[3],data1[3];
int time_array[402];
float data_array[402];
int t1=0,i=0,i1=0,ii=0,tt=0,ttt=0;
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(53)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("b.txt");
    while (myFile.available()) {
      //Serial.println(t1);
      //t1 += 1;
          if ( t1 == 0 ) {
             time[tt] = myFile.read();
             //memset(time, 0, sizeof(time));
             tt += 1;
             if (myFile.read() == ',')
                ttt = atoi(time);
                t1 = 1;
          //else {
            if (t1 >= 1) {
              if (i > 2 && t1 > 0) {
                data1[i1] = myFile.read();
                i1 += 1;
              else {
                data = myFile.read();
                i += 1;
                t1 += 1;
          if (t1 >= 6) {
          int k = atoi(data);
          int k1 = atoi(data1);
          data_array[ii] = k + (k1/100.00);
          time_array[ii] = ttt;
          Serial.println(time_array[ii]);
          Serial.println(data_array[ii]);
          ii += 1;
          i = 0;
          i1 = 0;
          t1 = 0;
          tt = 0;
  // nothing happens after setup
下圖為輸出結果
問題就是
從10開始就沒print.....
找不出問題在哪....
希望大大們能幫我看看哪裡有問題!!
GMT+8, 2026-10-3 07:05 , Processed in 0.161272 second(s), 10 queries , Apc On.
