查看: 4276|回復: 3
新手請教多棵LED同時閃爍後計時中斷~~誰能幫我看看><
發表於 2015-9-9 14:53:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是我最近寫的程式,但是無法中斷,update後怎麼計時中斷,換下個燈號,另外我有用到74hc595 所以是用shift()
unsigned long previous_time;
int latchPin = 26;
int clockPin = 24;
int dataPin = 22;
#define ULONG_MAX 0xffffffffL
#define latchPin2 A1
#define clockPin2 A0
#define dataPin2 A2
volatile unsigned long Count = 0;
// 將 latchPin, clockPin, dataPin 設置為輸出
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(latchPin2, OUTPUT);
  pinMode(clockPin2, OUTPUT);
  pinMode(dataPin2, OUTPUT);
previous_time = millis();
  TCCR1A = 0x00;                // Normal mode, just as a Timer
  TCCR1B |= _BV(CS12);          // prescaler = CPU clock/1024
  TCCR1B &= ~_BV(CS11);
  TCCR1B |= _BV(CS10);
  TIMSK1 |= _BV(TOIE1);         // enable timer overflow interrupt
  TCNT1 = -15625;               // Ticks for 1 second @16 MHz,prescale=1024
void update2(unsigned long time_passed){
  static unsigned long time = 0;
  time += time_passed;
  if((time / 200) % 2 == 0){ // 第一組的LED明滅頻率為0.2秒
       digitalWrite(latchPin, LOW);
     shiftOut(dataPin, clockPin, MSBFIRST, 1);
        digitalWrite(latchPin,  HIGH);
  else{
    shiftOut(dataPin, clockPin, MSBFIRST, 0);
void update3(unsigned long time_passed){
  if((time / 300) % 2 == 0){ // 第二組LED明滅頻率為0.3秒
     digitalWrite(latchPin2, LOW);
shiftOut(dataPin2, clockPin2, MSBFIRST, 1);
      digitalWrite(latchPin2,  HIGH);
  else{
    shiftOut(dataPin2, clockPin2, MSBFIRST, 0);
unsigned long current_time = millis();
  unsigned long time_passed;
  if(current_time > previous_time ){
    time_passed = current_time - previous_time;
  else{
    time_passed = ULONG_MAX - previous_time + current_time;
  if(time_passed >= 100){
    update2(time_passed);
    update3(time_passed);
    previous_time = current_time;
ISR (TIMER1_COMP_vect)
  Count++;
  if (Count == 5) {  //5秒後中斷
發表於 2015-9-10 08:37:07 | 只看該作者
你致能的是 OVERFLOW 的中斷
但用的郤是 COMPARE 中斷
所以只要把 ISR (TIMER1_COMP_vect)
改為 ISR (TIMER1_OVF_vect)
就可以了
 樓主| 發表於 2015-9-11 15:59:19 | 只看該作者
回復 2# 超新手
還是無法停止,我有個想法是會不會是用到mills() 導致不能使用count來處理 或者isr內程式太複雜, 到底要如何閃爍一段時間來中斷做另一件事?求救
發表於 2015-9-11 17:16:56 | 只看該作者
如果只是要做另一件事
不用那麼麻煩
把中斷都拿掉(含SETUP 中的致能)
然後LOOP改成
if(time_passed >= 100) {
    if(Count >= 50) {
    else {
      ++Count;
GMT+8, 2026-8-3 18:39 , Processed in 0.739838 second(s), 9 queries , Apc On.
