查看: 4522|回復: 2
swich case 問題
發表於 2015-10-6 17:50:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 j246810j 於 2015-10-6 17:52 編輯
使用swich case 他會一直執行case3 無法跳出  我的目標是想要無窮迴圈 也就是1→2→3後再重來一遍 有高手可以幫我看看ㄇ
unsigned long previous_time;
int latchPin =3;
int clockPin =2;
int dataPin =4 ;
#define ULONG_MAX 0xffffffffL
#define latchPin2 A1
#define clockPin2 A0
#define dataPin2 A2
volatile unsigned long Count = 0;
volatile unsigned long Count2 = 0;
volatile unsigned long Count3 = 0;
unsigned long current_time = millis();
  unsigned long time_passed;
  int flag=1;
// 將 latchPin, clockPin, dataPin 設置為輸出
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(latchPin2, OUTPUT);
  pinMode(clockPin2, OUTPUT);
  pinMode(dataPin2, OUTPUT);
previous_time = millis();
void update2(unsigned long time_passed){
  static unsigned long time = 0;
  time += time_passed;
  if((time / 200) % 2 == 0){ // 第一組的LED明滅頻率為0.2秒
       digitalWrite(latchPin, LOW);
     shiftOut(dataPin, clockPin, MSBFIRST, 1);
        digitalWrite(latchPin,  HIGH);
  else{
    shiftOut(dataPin, clockPin, MSBFIRST, 0);
void update3(unsigned long time_passed){
  if((time / 300) % 2 == 0){ // 第二組LED明滅頻率為0.3秒
     digitalWrite(latchPin2, LOW);
shiftOut(dataPin2, clockPin2, MSBFIRST, 1);
      digitalWrite(latchPin2,  HIGH);
  else{
    shiftOut(dataPin2, clockPin2, MSBFIRST, 0);
void update4(unsigned long time_passed){
     shiftOut(dataPin, clockPin, MSBFIRST, 128);
  else{
void update5(unsigned long time_passed){
shiftOut(dataPin2, clockPin2, MSBFIRST,128);
  else{
void update6(unsigned long time_passed){
  else{
void update7(unsigned long time_passed){
  else{
void Led1(){
  if(current_time > previous_time ){
    time_passed = current_time - previous_time;
  else{
    time_passed = ULONG_MAX - previous_time + current_time;
   if(Count >= 5000) {
       flag=2;
    else {
       if(time_passed >= 100) {//每次在loop裡,檢查距離上次更新是否經過了100ms(0.1秒),若是,呼叫update2、update3
     ++Count;
      update2(time_passed);
      update3(time_passed);
              previous_time = current_time;
void Led2(){
  else{
  if(Count2 >= 5000) {
           flag=3;
    else {
      ++Count2;
      update4(time_passed);
      update5(time_passed);
void Led3(){
  else{
   if(Count3 >= 5000) {
      com=2;
    else {
      ++Count3;
      update6(time_passed);
      update7(time_passed);
  switch(flag) {
case 1:
    Led1();
case 2:
    Led2();
case 3:
    Led3();
發表於 2015-10-7 08:11:50 | 只看該作者
你的 current_time 只有開機給初始值一次
應該在 LOOP 中, 每次都要讀一次目前的時間才對吧?
switch(flag) {
case 1:
 樓主| 發表於 2015-10-8 15:41:30 | 只看該作者
感謝大大的幫忙 發覺只要把Count1 Count2 Count3做個歸零就會開始迴圈了
GMT+8, 2026-10-3 08:30 , Processed in 0.183203 second(s), 8 queries , Apc On.
