查看: 3994|回復: 0
關於用藍芽控制自走車的程式
發表於 2015-10-19 22:40:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最後由 kocli 於 2015-10-19 22:51 編輯
因為我們買這台自走車的時候他就有附上程式了
但是我看不太懂 可否請各位大大們幫我加上註解讓我瞭解一下這程式在寫什麼@@
勞煩和辛苦各位大大了
const int KEY_NOTHING = 0x0;
const int KEY_UP = 0x1;
const int KEY_DOWN = 0x2;
const int KEY_RIGHT = 0x4;
const int KEY_LEFT = 0x8;
const int DELAY = 300;
unsigned char Motion_val;
unsigned char Receive_val;
unsigned char FLAG;
unsigned char len;
unsigned char Buffer_temp[4];
unsigned char i;
void UART_FUN()
  for(i=0;i<5;i++)
   Buffer_temp=0x0;
    delay(100);
  while(blueToothSerial.available())
     Receive_val=blueToothSerial.read();
      //Serial.print(Receive_val);
     // Serial.print("\n");
     if(Receive_val==0xAA)
len=0;
Buffer_temp[len++]=Receive_val;
     else if(len < 5)
  if(Buffer_temp[0]==0xAA && Buffer_temp[1]==0xBB && Buffer_temp[3]==0xF1)
   Serial.print("UP \n");
   Motion_val=KEY_UP;
   else if(Buffer_temp[0]==0xAA && Buffer_temp[1]==0xBB && Buffer_temp[3]==0xF2)
   Serial.print("DOWN \n");
   Motion_val=KEY_DOWN ;
   else if(Buffer_temp[0]==0xAA && Buffer_temp[1]==0xBB && Buffer_temp[3]==0xF4)
   Serial.print("RIGHT \n");
   Motion_val=KEY_RIGHT ;
  else   if(Buffer_temp[0]==0xAA && Buffer_temp[1]==0xBB && Buffer_temp[3]==0xF8)
   Serial.print("LEFT \n");
   Motion_val=KEY_LEFT ;
   else   if(Buffer_temp[0]==0xAA && Buffer_temp[1]==0xBB && Buffer_temp[3]==0x00)
   Serial.print("KEY_NOTHING \n");
   Motion_val=KEY_NOTHING ;
bluetooth_car.ino
3.7 KB, 下載次數: 4160
自走車
GMT+8, 2026-8-3 18:39 , Processed in 0.480784 second(s), 10 queries , Apc On.
